RE: Plane won't fly level!
All aircraft respond to thrust changes (throttle) with a change in pitch (elevator).
The one item you did not mention is are you trimming in down elevator in response and does that help? Also can you fly at a steady reasonable power setting and trim the airplane so it hold altitude?
There is always the possibility that you have a small incidence problem.
So can you trim the airplane for level flight at a fixed power setting and does that result in a lot of down elevator from a normal intrail position?
John
