ORIGINAL: THErcnoobie
if weight does not make the wheelbase extend there is a simple solution.limiting straps will have to be applied.then there you go all done with that.take your time ion this project.we have patience and we can wait a bit longer to see the exhasut pipes.
yes the limiting straps to axle is a very good idea and simple to do... i used to keep them tight on my landy to have the required wheelbase. Now that i changed everything i dont need them any more. I used chain but you can use anything that holds.
