RCU Forums - View Single Post - Plane won't fly level!
Old 04-04-2009 | 11:32 AM
Campgems
Default RE: Plane won't fly level!
ORIGINAL: JohnBuckner
There is always the possibility that you have a small incidence problem.
John
I think John hit it on the head there. My ARF trainer was flying just as you descrive, a slight change in throttle would result in huge pitch differences. At the last, I had a stack of four popsicle sticks under the TE of the wing and it was flying much better.
I also had a 4*60 that I broke the tail off of and when I repaired it, I screwed up the horziontal stab inicidence just a bit. I had to fly with a bit of down elevator trim, but this was sensitive to throtle.
I would get an incidence gage, or rig one up and see where you stand. I'll bet the wing is off a bit, probably to much incidence. You have a low wing, so if you were to put one popsicle stick between the wing and fuselage at the TE, your problem should be a little worse if the incidence is the cause.
One other possibility is motor down thrust, You could always add a washer or two on the top two screws on the motor mount to give a little more down thrust.
Don
Don
