RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT
Hi aeajr,
the detailed write up has been a very useful tool for me to understand the electric way. I however am confused on a few questions. what power set up will i need for the multiplex easycub that i want to use for AP. the equipment will be around 250gms. i wanted to go for a 350 watt set up. do you think i am right. can you please suggest the power plant for the same ( motor, ESC ). i will use a 11.1 2200mah 20c battery for the same. what flight time will i get. thanks.
