RE: Top flite Cessna 182 Servo location
Hiii
Yeaah.. some things still happening on the Skylane... Our shootingrange has reopened after winther. so im praticing IPSC again..
I have hinged the tail surfaces with robart pinhinges. Pretty easy to work with i think. The wing has been run over with some filler.. not many spots needed it so that good.
Covered the wing with glas, just need to make the edges and cover the flaps and ailerons. That will be next.
The fuselage needs to be covered also with glas. Only the tail, dorsal fin is covered at this point.
