RCU Forums - View Single Post - Everything you want to know about electric flight
Old 04-05-2009 | 09:23 AM
  #61
campcrafter
Default RE: EVERYTHING YOU WANT TO KNOW ABOUT ELECTRIC FLIGHT
ORIGINAL: aeajr
Of course that depends on what performance you want, which you did not state.
what power set up will i need for the multiplex easycub that i want to use for AP.
thank you for your reply.
I have already stated that the cub will be used for AP, i.e. aerial photography.
i have gone thru your writings and i have to complement you, that my knowledge of electrics has been phenominally enhanced , thanks to you again.
now my confusion is about the amperage, voltage, wattage kv, that are mentioned or not mentioned on the specification by the company. then what is the way out. see the links below.
http://www.multiplexusa.com/power_an...power_pack.php here the is Himax 2816-0890 Brushless Motor, where the dimension is 28 x 33, then why 2816?
http://www.hobbycity.com/hobbycity/s...trunner_1200kv. we know the voltage, where's the current mentioned? what do we do? can we rely on the vendors word? what if there's a typographic error?
http://www.hobbycity.com/hobbycity/s..._1400Kv_/_470w Here the Rated Power: 470w is mentioned and in the configuration table: Power(W) 345 is written. How does a novice like me understand.
If you can explain this, it would benifit many.
thanks again.
