U-CAN-DO-46
Hi,
My model has been delivered. Boy oh boy are these control surfraces massive.
I'm going to run an OS 50 with it and start with a 12X4 prop.
I've re-glued the fuselage in all the areas I could reach and re-glued the belly pan as well. I thought the glue was on the light side when I looked at it. The horizontal stab was a little bit off so I sanded the high side on the fuselage and it came out right on the numbers.
The engine bolted up without a hitch.
The vertical stab went on without a hitch.
I'm running 9202's on all control surfaces. .
Building has stopped until I get the servo extensions for the rudder and elevator
Regards,
Scooterpilot
