Problem with P60SE
I had problems yesterday with a brand new P60SE (ECU 6.00 Q), I could only get it to start 1 time (second time I tried), the other tries it went to "accell state", temp around 300 deg, and then just a white "puff", it stayed in "Accell state", and I had to shut it down from the TX.
I have tripple checked valves, installation etc (it's in a new Boomerang Sprint), I swapped the engine over to my Baby Boomerang where it worked ok.
I then took my engine from the Baby Boomerang and put it into the Sprint, "white puff" on that also. So it is the installation in the Sprint that is somehow the problem, as the engine itself seems to work ok.
I have done the "purge fuelsystem" and "burner valve" tests, and the fuel is coming ok in both tests.
I even tried disconnected the main fuel line, and tried a start, the fuel comes as it should in the startphase.
Only different thing is that the valves I got with the engine was "Xicoy" valves and not the usual "Cat" valves....
I will do some swapping of the equipment later on, and see if I can pinpoint what the problem is.......
But I thought I would ask if any of you have any good ideas ?
