RCU Forums - View Single Post - How much gap is too much
Old 04-05-2009 | 10:59 AM
Rodney
Default RE: How much gap is too much
Contrary to some comments above, a gap does NOT cause flutter. It does lower the response (the smaller the gap the more control you have for the same amount of physical movement) rate. A gap could initiate flutter by stimulating the resonant frequency of the surface. Every thing will flutter if given the proper stimulus. Ideally the only surface that will not flutter is a surface of zero mass and infinite stiffness, a totally unobtainable ideal so the best we can do is make the surfaces as light as possible yet retain a high degree of stiffness. Most sport models will fly perfectly well with very large gaps between stab and elevator but can be somewhat sluggish if the gap is large.
