RCU Forums - View Single Post - clevis or z-bend?
Old 04-05-2009 | 11:57 PM
Alex7403's Avatar
Alex7403
Default RE: clevis or z-bend?
you must solder the throttle cable into the clevis, but before you do it make sure that the nyrod is not restricting the movement, its a Bit_h to shorten it when the clevis is soldered.
soldering the servo clevis [:-],
well for me its not the preferred connection because i like to have this degree of freedom otherwise thats it and you cannot change anymore.
Lock tight doesnt do it? get 2-56 nuts you will need them in the future.
meanwhile i would go with some nylon clevis instead of soldering them permanently.
Alex
