RCU Forums - View Single Post - How much gap is too much
Old 04-06-2009 | 07:12 AM
sensei's Avatar
sensei
Default RE: How much gap is too much
ORIGINAL: Rodney
Contrary to some comments above, a gap does NOT cause flutter. It does lower the response (the smaller the gap the more control you have for the same amount of physical movement) rate. A gap could initiate flutter by stimulating the resonant frequency of the surface. Every thing will flutter if given the proper stimulus. Ideally the only surface that will not flutter is a surface of zero mass and infinite stiffness, a totally unobtainable ideal so the best we can do is make the surfaces as light as possible yet retain a high degree of stiffness. Most sport models will fly perfectly well with very large gaps between stab and elevator but can be somewhat sluggish if the gap is large.
What he said for sure...
Bob
