ORIGINAL: UStik
The MAN Taurus has the rearward c/g location given in the plan (says 4.75" to 5" behind center leading edge). It needs the slightly rearward c/g both for level-flight trim and for spinning. Despite the elevator throw even bigger than specified and the "terrific" (as Ed calls it) rudder throw, it doesn't spin in the forward c/g position and hardly in the rearward. The Nats Taurus is a bit more stable with the forward c/g position, is still trimmed for level flight, and with the rearward c/g position spins even docile. It's a bit more dampened as well.
I wouldn't sweat the flight characteristics in the simulator too much, they are simply adjusted as descibed by Ed so they can't be completely wrong. After all Ed himself says in the articles that even each model of the same type is slightly different. Now the simulator gives us one important benefit (compared to reality): We can make two models exactly the same and then modify only one parameter (e.g. tail cone length) to assert the differences in flight behavior (e.g. easier spin).
What about the Taurus-2 with the Bosch(sp) airfoil. The wing is 1" more forward than the others, (making 1" longer tail moment, and the longest of all the Taurus versions)? Do you have that one in that simulator? Do you need measurements, since I now have the plane home wth me.
It would be interesting to see how it vaies with the longer movement and altered airfoil....should spin better.
Picture this photo, (only up in the air).
Duane
