RCU Forums - View Single Post - Maybe "outside the box" programming transmitter
Old 04-06-2009 | 08:23 AM
gittarpikk's Avatar
gittarpikk
Default RE: Mayby "outside the box" programming transmitter
Much more advanced than a foamy....but would use a similar setup.. The difference is that rudder and aileron are different from a foamy setup. BTW the images for whatever reason did not generate a thumbnail image so you have to click them to see them. View is from the rear (ie top fin, right fin, left fin, bottom fin) (each has its own servo per surface.)
