RE: this bubbles are going to turn me crazy
I had the same problem on a TH 61. I used the little zip ties to secure all the permanent fuel line connections, including inside the tank, and it stopped the bubbles. The only connection that doesn't get a zip tie is between the tank and the high speed needle that I use for fueling.
