RCU Forums - View Single Post - Maybe "outside the box" programming transmitter
Old 04-06-2009 | 10:38 AM
gittarpikk's Avatar
gittarpikk
Default RE: Mayby "outside the box" programming transmitter
ORIGINAL: RC MANIAC119
You typed an awful lot of words..........and didn't answer a single question! I got the thumbnail thingy.....Now, if your little project is top secret stuff.....then fine, be a vague as you possible can. But if it's not, I need to know what you mean by similar but different!!
Will the Ailerons function as Ail's only, or also as Elevators also? Same question for the Rudder......will it be Rudder, and then Aileron?
Yes, it will be vague ...for a reason....
I want the rudder to "twist" the whole system.. (ie right twist, left twist) but controlled by left stick (normally rudder on mode 2... I think)
I want the aileron to move what normally would be seen as a rudder surfaces (both top and bottom fins but those only)...but the stick that moves them is the aileron stick (standard mode 2 I think I rember it as)
I want the elevator to move the horizontal fins....(right and left side ...but those only)
so its a bit different from any foamy setup or even a delta config
maybe this will clear it up..
