RCU Forums - View Single Post - Engine Start by bouncing off the compression stroke?
Old 04-06-2009 | 01:20 PM
pdm52956
Default RE: Engine Start by bouncing off the compression stroke?
My OS flip started on the second try right out of the box. Never have used a starter on it. Proper priming is required or it will start in reverse, but it won't hurt it when it does this. Easy way to tell if that happens is to 'feel' which way the wind blows from the prop. On my OS, if it does start in reverse, usually a blip or two of the throttle will send it in the right direction.
