RCU Forums - View Single Post - Tilting a lawnmower motor 90 degrees.
Old 04-06-2009 | 01:56 PM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Tilting a lawnmower motor 90 degrees.
There are some pump carbs or Walbro type used on some lawnmowers. Perhaps one could be adapted to this engine. With a float carb you will be forced to use a tank above the engine with limited areobatics. Little to no inverted flight.
