RE: tower.46 nitro engine
You might also make sure the tubing is flexing enough to reach the bottom of the tank when the level is low. I have an eight ounce dubro tank that I replaced the fuel lines and clunk in and the new silicon tubing I used was not flexible enough to let the clunk fall to the bottom of the tank, it just kind of hung at about 1/3 tank level as you describe.
