RCU Forums - View Single Post - Buddy Box Trims- WAY OUT
Old 06-15-2003 | 11:53 PM
Highlander
Default Buddy Box Trims- WAY OUT
Nova
explain how you are useing the buddy box , ?
does it have batteries in it , ? if it does remove them
does it have a crystal in it ? if it does remove it .
make sure that the channels are correct IE switched to the same direction and same controls on the sticks .
do not even turn the switch on ,on the buddy box it is not needed.
other than that I cannot think of a reason for the surfaces to change when it is in use .
Highlander
