Buddy Box Trims- WAY OUT
Nova, could you check if the throttle stick and elevator stick on your 4VF move the same distance up and down. In mine the throttle moved less and I found that I had to remove a small plastic travel limiter from the gimbal assembly behind. If you need more info on this, do a search in the radio section under 4VF.
