RCU Forums - View Single Post - PT 40 Rolling to the right
Old 06-16-2003 | 02:01 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default PT 40 Rolling to the right
Originally posted by Hostile Rekit
It still is balanced when I pick it up by the spinner and the vert. stabilizer.
This may not be accurate. Try suspending the model using kevlar string or fine wire hooked to the middle landing gear mounting bolt and the tailwheel mounting bolt. I've done what you did before and what seems balanced using this method, is not using the suspension method. The spinner also has some rotational resistance from the engine mechanism. I'd also go with what Cwatkins said. Just my 2C
