RCU Forums - View Single Post - Maybe "outside the box" programming transmitter
Old 04-07-2009 | 07:24 AM
gittarpikk's Avatar
gittarpikk
Default RE: Mayby "outside the box" programming transmitter
No...from what I could tell...but I only could get a very small pic out of clicking... but no, not even a little bit......BUT...the surfaces seem to mimic the description I have above.. What is this?...is there a bigger picture available? All I can see is it looks like some sort of freeflight (but maybe rc controlled) pinwheel apparatus
I have found something that >may< work...have to read a lot of a few different threads to see if the method they use (mix) can do what I need done. You can find this craft known as a "hoverfoam" by googling it
or here a is thread on it
http://www.rcgroups.com/forums/showt...ight=hoverfoam
The surfaces you show may be a more accurate way of doing what I need done.....My "project" is involves none of the above...nor the hoverfoam...however, it will probably use the same control functions/system but actually completely in reverse....but that is easily fixed once the system/mix is set up....so I won't go into that realm yet.
Now for all practical purposes, let's discuss the controls (or making them better/more effective ) for a hoverfoam.
