ORIGINAL: UStik
Oh well, couldn't wait, T2 flies virtually.
As you may expect, it spins very well and even snaps/flicks like crazy! In fact, you can stall it in level flight and it will bank and try to spin, so be careful. I set elevator throw to 30 degrees (25 is enough) instead of the 40 degrees kick-up (is no longer needed because T2 was proportional). It's not vicious though, just stay one mistake high when coming near stall, should be enough to pull out safely. I can't guarantee for the realism of the virtual model, but it surely shows general behavior.
I'm sure because the better spinning doesn't come from the airfoil, at least not directly. The airfoil's stall behavior is not very different from that of the NACA 2419. The wing planform isn't that spin-promoting, either, even though the point of first stall is a bit more outboards. If the model is set up with the very stable 15% static margin (forward c/g) like the T1, it is just as reluctant to spin as the T1.
The small static margin and neutral behavior is possible because there is no airfoil pitching moment. The elevator is more effective as well. The wing is a bit sleeker than the T1 wing and you have to plan your landing approach to bleed off the speed. The ST 58 will not pull "faster" because rpm and propeller are the same, but it pulls much
more (0.94 thrust/weight, 6 lb overall weight) than the Veco 45.
T2 is a much more modern model than T1, neutral, smooth and powerful, predictable, soft landings. Still terrible couplings, much belly pitch and positive roll. Not vicious, just be careful with stalling maneuvers. Don't be scared, c/g is 8.5" behind center leading edge on the virtual model. Again, no guarantee, but expect a great flier!
P.S.: You can start with the c/g 3" more forward (or even more), the model is still under control, just with substantial elevator. Then gradually approach the right c/g position. Just in case you inted to fly the T2 at Easter.
