RE: limit needle valve
Just for the record - I reviewed the EVO TPS a few years ago and mine would not run right. I called the manufacturer and was told that several of them got through QA with the wrong low-end needle setting.
The PROPER low-end setting should be as follows:
Remove the blue collar from the low-end adjustment.
Open the carb 1mm
Close the low-end needle
Open the low-end needle 1 1/5 (one and one fifth) turns
Replace the collar.
