ORIGINAL: UStik
..... normal people to upgrade to T2 standard. In this case/phase that meant swept wing, more dihedral and shorter tail. As you wrote before, Ed soon realized this to be wrong, and even though the Japan T2 flies quite well the final T2 is noticeably better. If Ed had reduced the dihedral further he would have had an even better ship.
A more technical explanation could be the symmetric airfoil. Due to the absence of down pitching moment quite small static stability margins are practicable, and they are desirable for neutral flight behavior. But this in turn might require a longer tail and shorter nose for better damping.
HUH???[:-]
Define "static stability" and "damping" auf English bitte
Duane
