RE: Some rust on piston... Solutions?
You can soak the engine in glow fuel (something I do every spring before running) and that should loosen up some of the assumed castor. Castor will have a brownish color when burned. What fuel have you been running? I would say if you don't soak it in fuel just to run it. It is not rust.....thats for sure.
Kevin
