ORIGINAL: Ron101
Really great news!!!
will there be an adaptor for diffenet fans? 100mm 110mm 120 mm and such?
Did you fly it on the TJ100's ? How many cells?
Thanks Much
Ron
Hey Ron
I have a slightly different sructural setup for the cheap chinese 110mm fans for the engine nacelle but for the most part i think it would be fairly easy for the buyer to adapt it over. We have not messed around with enough setups to say we could offer something like this yet. Are you still thinking about the Stumax fans. When i get ready to do mine, i was wanting to set it up with Stumax fans so i will definately be making an adapter for these fans. I will be pretty busy for awhile so it may be some time before i even get around to purchasing some Stumax fans. If the time comes and you need some adapters you could send me the fan shroud and i can do some up for you. I live in central california which i believe is pretty close to where you are at.
thanks
chris
