RCU Forums - View Single Post - steering throttle
Old 04-08-2009 | 10:00 PM
el_tonto
Default RE: steering throttle
The 3003 is an entry-level servo. I'd stick with something a bit beefier to turn the big Volcano wheels. The 3003 is about 3kg.cm of torque, you probably want at least 5-6kg.cm for the Volcano.
It is compatible though. Most servos are - the pinout nowadays is the same across brands, as is case size.
