RCU Forums - View Single Post - here's a good one !!!!!!!!!!!!!!!!!!!!!
Old 06-18-2003 | 04:42 PM
Ron S's Avatar
Ron S
Default here's a good one !!!!!!!!!!!!!!!!!!!!!
There is a low pressure area located on an airfoil at moderate angles of attack, on the forward top surface. This distribution would tend to lift the leading edge up.
Hitec I believe have a 90 oz-in retract servo available, but you are right that space might be a problem. I'd stay away from a torque rod arrangement, if I were doing it, but that would allow you to keep the servos inside the fuselage or LEX). Perhaps a couple of air cylinders along the span is the way to go, as previously suggested. I'm assuming this is the big F-18 kit?
