RCU Forums - View Single Post - here's a good one !!!!!!!!!!!!!!!!!!!!!
Old 06-19-2003 | 01:13 AM
backstab
Default check it
I figure a strong sail winch type in the wing root, actually the fuselage driving an axle that goes through the root end of the le flap, when u plug the wings to the fuse on setup, u plug in the le flap square end into the square hole in the fuse elage, much like the Byron ailerons on say the A4 skyhawk (if you've ever seen that)
