RCU Forums - View Single Post - Crashed Receivers
Old 04-09-2009 | 08:46 PM
rabraaten
Default Crashed Receivers
I wasn't getting much help in the radio section of the forums so I'll try here...I've crashed my JR RS600 receiver a couple of times now. The first airframe was a total writeoff. I did a throrough range check, running, on the second airframe and had no troubles for 30 or so flights. This one pancaked hard enough to pull the firewall off, dumb thumbs not radio related.
As I'm repairing the plane I pulled the receiver and all out and found that the case is cracked, couple of small pieces of plastic missing. I have little doubt that this crash was far less dramatic than the last one and I'm not sure if the damage was there last time or not. I will of course thoroughly range test this receiver as well before I fly it again. Can anyone out there tell me exactly how and what Horizon (or any other repair type facility) would check if I sent this in for inspection/repair? I've looked a bit into sending it in but the cost seems like it may not be worth it. (As opposed to just replacing it...)
Ryan
