RCU Forums - View Single Post - FOD
Thread: FOD
Old 04-10-2009 | 03:12 AM
madmodelman's Avatar
madmodelman
Default RE: FOD
It's worth it for the sun you get out there!
Talking fods, my new P-80 makes a whirring noise on initial spool up (electric) if I waggle the fod gaurd a bit it goes away. Ali made a comment that I will knacker the o ring/start motor. It appears to be caused by the main fuel feed putting a little tension on the flexible motor mount as I have made it a close fit. Is this normal or should I open the hole in the mesh a bit to relieve it? Gary.
