RCU Forums - View Single Post - How much gap is too much
Old 04-10-2009 | 07:03 AM
sensei's Avatar
sensei
Default RE: How much gap is too much
Sloppy linkage will cause flutter, but gap is not the cause of flutter at all, it will cause your surfaces to be less effective, no doubt about that.
Having a gap only changes the frequency that excites flutter mode; sealing the gaps in some cases can actually induce flutter over an open gap. The only real way to protect your aircraft from flutter is to: 1 mass balance the surface, 2 use servos that will handle the loads, and 3 the likage has to be tight, and slop free, its that simple...
Bob
