Pitviper is this the engine that made a funny sound before. If so it looks like you spun the bearing in the case or your prop hub nut is way loose. You are right that is not supposed to be that way. Decide to edit this because I have never seen an engine with that much end play on the gas engines I have. Just my reasons and then maybe this is correct for this engine.[
