RE: Question on .09 paw diesel
So far the info sounds encourageing. I know you have to be careful when choking/priming not to get a hydrolic lock and bend the rod, so I'm very careful when using a starter. I can't get it to start by hand. The only thing I'm not sure about when adjusting the fuel mix on the carb, after its running, do you rev it up and adjust like a glow engine? Is it better to run rich then turn leaner a little or run lean and open until it smooths out. It appears it likes to run better on the rich side. Terry
