RCU Forums - View Single Post - Size of set screw
Old 04-11-2009 | 09:27 AM
lmyers10
Default RE: Size of set screw
I picked up the blue and used it. This is on info from the LHS. They are 3mm set screws. And regular 3mm set screw will not work unless you grind a chamfer on the bottom of it.
