RCU Forums - View Single Post - The Wings Maker Ultimate 40
Old 04-11-2009 | 10:21 AM
Greg Covey's Avatar
Greg Covey
Default RE: The Wings Maker Ultimate 40
The Ultimate 40 ARF comes very well protected in its box and every part is sealed in plastic. The plane is beautifully covered and detailed. The kit includes built-up upper and lower one-piece wings and an incidence guide set for checking the alignment between the two wings.
The fiberglass cowl is painted and comes with a plastic guide for cutting sections away when a glow engine is used. The wheels, fiberglass pants, spinner, and fuel tank are also included. The opaque canopy eliminates the need for a pilot.
An 13-page manual with detailed drawings and a decal sheet are also included. The manual reveals detailed linkage assembly and instructions to properly set incidences. It clearly states the proper throws and CG settings.
After opening the large bag of parts, it was nice to see the smaller bags with numbers on them that matched the instruction steps in the manual. This makes it easy to find the right set of parts for each step and is a nice feature from The Wings Maker!
ID:	1177753   Click image for larger version
ID:	1177754   Click image for larger version
ID:	1177755   Click image for larger version
ID:	1177756   Click image for larger version
ID:	1177757   Click image for larger version
ID:	1177758   Click image for larger version
ID:	1177759   Click image for larger version
