ORIGINAL: GlassBullet
what do you mean "dragging"? like staying engaged a little?
Yes. If the wheels are turning at idle on a stand, its because the clutch is engaged. Assuming its not a problem with the clutch (weak springs, shoes that need to be filed) then your idle is too high.
