I have an older .60 sized cub which i am installing a Magnum .70 4S in, My question is the fuel inlet on the carb is about 3/4 to 1" above the center of my fuel tank. I cannot raise my tank or lower the engine as the orignal owner set it up with the engine running 90*. what kind of problems will i encounter with the carb inlet being higher than the tank and will i need a pump for this set up? Any idea's???
Thanks..
