RCU Forums - View Single Post - yaw
Thread: yaw
Old 04-13-2009 | 11:14 PM
jrcaster's Avatar
jrcaster
Default RE: yaw
If you still want to set diferential throws, you can use the smaller disks. Make sure to drill the holes in the proper positions as far out as you can, doublechecking your angles. Then screw your aileron horns in till you get the proper throws.
Smaller disks, shorter horns.
