RCU Forums - View Single Post - FLy Eagle Jet Models
Old 04-14-2009 | 08:29 AM
  #1701
KC36330
Default RE: FLy Eagle Jet Models
ORIGINAL: starman62
Hey guys on the brakes do you hook up the brake valve with the elevators so when you give down elevator the brakes work are is there a better way to do this?[8D]
most of the people who use the down elevator mix do so because it's a 'learned' habit from back in the days when channels were limited and the best way to get brakes was to put a trigger switch that was activated by the servo horn when down elevator was applied. these days you typically have more then enough channels to put the brakes on their own channel and use a switch or slider. some people still use the down elevator mix for taxi braking and have a switch or slider for parking brakes.
