RCU Forums - View Single Post - Fuel feeding question
Old 04-14-2009 | 01:40 PM
tschuy
Default RE: Fuel feeding question
You shouldn't have a problem feeding the engine with the tank being lower. Just means that the needle valve setting will tend to be more open then what it was in a prior aircraft. Do use the pressure feed from the muffler and be aware that if you fly the cub upside down, your engine will tend to go rich.
