RCU Forums - View Single Post - X-treme Composite Altair 200
Old 04-14-2009 | 03:59 PM
riot3d
Default RE: X-treme Composite Altair 200
Some progress has been made this week, the aileron servo and connection is done. I'm using push rods from Creative Models, rod ends from Hirobo and horns from Nishioka. Since the push rods' length are pre-determined - 55mm - it took a bit of cutting & measuring to ensure a correct fit.
Whenever I install servos on a plane with a one piece wing configuration, I always glue a small piece of foam inside the servo lead opening to prevent the leads from dropping back into the wing by accident.
ID:	1180333   Click image for larger version
ID:	1180334   Click image for larger version
ID:	1180335   Click image for larger version
ID:	1180336   Click image for larger version
ID:	1180337   Click image for larger version
