Engine tuning
It says in these break in instructions I have to:
Set your high-speed needle at 2 1/2 turns out—turning it clockwise from the closed position—and your low-speed needle at between 1 and 2 turns out. The idle-speed screw should be set so that you can see an opening of about 1mm in the carb’s barrel.
If the high speed needle is at a closed position how are you supposed to turn it clockwise? Isnt a closed position lean and the more open the needle is the more rich or am I backwards? Clockwise lean, Counterclockwise rich?? Am I right here?
