RCU Forums - View Single Post - Lost Prop on Saito 100 This Weekend.
Old 06-18-2003 | 01:23 PM
flytlust
Default throwing props
Use 40 grit sandpaper disks between your spinner back plate and prop, and between the nut washer and prop. also on the Saito's the low end needle is quite rich. you will have to adjust it after break in to get smooth transition. Great tracters when adjusted properly.
