RCU Forums - View Single Post - last order
Thread: last order
Old 04-16-2009 | 01:38 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: last order
You won't need the Sullivan adapter. The starter will come with one in it, so you don't need to buy an extra one. Also, don't buy wooden props. New pilots and wooden props DO NOT mix well. The first time you touch the prop to the ground it's going to shatter and need replaced. I recommend that all newer pilots use Master Airscrew as they can take a bit more of a beating and still work. Also, never buy just one prop. That's a sure fire jinx to breaking a prop, not having a spare. I always buy 2 at a time, especially for newer pilots
If you can I would recommend buying your fuel locally. It's going to be much more expensive if you buy it from Tower.
Ken
