RE: WOOD PROP OR PLASTIC PROP?
First of all, new pilots should use plastic.. either Master Airscrew or APC.
Wood props will pretty much shatter as soon as it hits the ground, which is what new pilots do a lot. You have an even chance of having a plastic prop last a bit longer.. buy several spares.
Balancing is always a good idea. Some won't need it, but checking it is what is necessary.
A good quality plastic prop will be just fine. It may flex a bit but it is fine to learn with. Pick the size that suits you and your flying style. Watch the full throttle RPM and don't exceed 12000 rpm. Excessive rpm do no good at all. Noise does not equate to power.
CGr.
