RE: Need help identifying a couple more planes
On the second plane I believe you are showing a mismatched wing and fuselage. The fuselage is definitely an Ultrasport which was a tail dragger airplane.
The gear placement in the wing shows that the setup it was meant for is a tricycle gear airplane with a nosegear. I can't tell for sure but I would almost bet that the wing is not an Ultrasport wing.
