RE: CMP C-160 Transall Electric Conversion
Hi all,
I'm starting to build the CMP Transall / electric conversion. My set up:
2 x Turnigy 25-36 1300kv
2x 9x6 apc prop
2x Turnigy Plush 40a esc
2x 35-35 motor mounts
The distance between the firewall and the tip of the nacelle is 10cm. Using the 35-36 motor mounts (5,5cm) is a perfect fit with the moto installed upside down (opposite side of the outgoing shaft).
These motors sould develop about 37 amps WOT and nearly 400 watts each, for a total of 750 watts and a ratio of 130 watts per pound. I am confident it will be enough to have scale-flying fun with this plane.
Philbel
