RE: problem_os200_pump
thank you bax,
i have lean the engine like you said, but how can i set idle mixture ? today, 3 flights, and same problems...on ground, after few seconds, my idle varies. Could it be a problem with pump or regulator ? how can i know that ? is it possible to verify myself pump or regulator ?
thank you
